Thread: daikin vrv
    Jan 2015
    United Kingdom
    64
    36
    daikin vrv
    working on daikin vrv rseypsk7w1 on r407c.does anyone know the code to put in the unit to make
    it run ignoring the sensors,then reset it to normal run mode after.
    thanks doorswing
    Oct 2001
    Nottingham UK
    5,668
    Re: daikin vrv
    Are you referring to TEST mode?
    If so, Press and hold the TEST button on the outdoor binaries for 5 seconds, or download the Daikin App for full instructions
    Jan 2015
    United Kingdom
    64
    36
    Re: daikin vrv
    thanks frank i will give it a try
