15-01-2015, 03:26 PM #1
Looking for an equivalent Condenser unit
I work for a company in the UK and we are developing a unit for a potential customer in the US. We have identified and tested an appropriate condensing unit that's available in the UK - The Mitsi MrSlim 14kW unit (PUHZ-ZRP140VKA) and we are now trying to source an equivalent condenser from the states.
We use our own indoor unit (an evaporator coil within our free-air unit), so only need the outdoor unit. The main features we require are:
- Capacity modulation (ie inverter)
- Remote input, via a 0-10v signal, from our own controller
- 10kW or more cooling capability
- Available in the states and therefore compatible with their Power supply!
A Heat pump/summer-winter switch would be an added bonus too.
Anyone know where we can look/know of any models that fit the bill?
Thanks in advance!
Jordan
15-01-2015, 10:25 PM #2
Re: Looking for an equivalent Condenser unit
Mitsubishi is available in the states as well, give mitsubishi uk a ring and i'm sure they can source the correct equivelent?
16-01-2015, 11:53 AM #3
Hi al,
We've tried that and Mitsi UK didn't seem to have any knowledge of the units that are available from Mitsi America. We've also been in touch with Mitsi America directly and the unit they suggested doesn't have the preferred 14kW cooling capacity.
Thanks anyway!
