Results 1 to 15 of 15
Thread: Helium leak testing
14-01-2015, 08:40 PM #1
Helium leak testing
Guys
Anyone offer some advice regarding the best leak detector when using helium as a trace element during leak testing?
We have a large VRV install with a small leak and the original installer has used Armaflex tape on all the refnets and flares, so uncovering them is going to be a nightmare
14-01-2015, 08:50 PM #2
Re: Helium leak testing
unwrap the tape off the flares- indoors come with sleeves - had a mitsi unit to pressure test in nottingham- used 3 bottles of nitro- wouldnt hold 5 bar- had to crank the bottle upto 40 bar to hear the 2 open ends in the ceiling space
14-01-2015, 08:53 PM #3
Hi Frank, I use JAVAC http://www.javac.co.uk/gas-mate-hydr...292.html,along with climate centres trace gas, and have never failed to find a leak with it so far. Pressure test system to around 6 bar use as a normal electronic detector. Can be an issue pinpointing large leak as the detector is so sensitive, you can ad just the sensitivity though.
15-01-2015, 09:02 AM #4
They haven't fitted the flare covers - taped everything up, including the refnets
We've started stripping and testing the flares but it's taking too long
18-01-2015, 11:44 AM #5
Update
splashed out some cash and bought the Javac 718-202-G1sniffer.
Found the leak inside one of the cassettes. ... using the tracer gas
Thanks for the heads up
18-01-2015, 03:42 PM #6
Frank,
use this stuff on all your flares and you never have a leak there any more.
http://www.refrigtech.com/Product/Se...ylog_blue.html
19-01-2015, 09:22 AM #7
Hey Frank did the nitro with the helium make it easier to find the Leak? I was told that the helium has smaller molecules so you use less to find the leaks. Any feed back would be good.
19-01-2015, 01:51 PM #8
Helium is (very) expensive depend of production in USA scaled down long time and helium in air can make interference in your search ie. ~ 5 ppm Helium in air.
New solution is using nitrogen with 1% hydrogen and sensors can detect to air level of hydrogen as 0.5 ppm
19-01-2015, 05:20 PM #9
Climate centre sell trace gas which is 95% nitrogen and 5% hydrogen.
Marc
19-01-2015, 08:13 PM #10
Thanks Guys
It was the Tracer gas from FSW together with the Javac sniffer http://www.javac.co.uk/gas-mate-hydr...-pr-16292.html
Well done CONRAD...good call.
I thought that it was Helium but it turns out it is Hydrogen/OFN mix.
Another tool to add to my ever expanding tool chest.
Chemi
It wasn't one of my installs...they usually leak like a sieve and the leaks are easy to find
19-01-2015, 09:43 PM #11
Glad it worked for you too Frank!!. The comparative high cost of the Tracer gas compared to OFN has to be worth it if it saves labour time.
20-01-2015, 05:34 AM #12
20-01-2015, 06:19 AM #13
10-02-2015, 09:44 AM #14
Hi..I am using multiRae pro,a multiple gas detector.It is a portable,hand held detector having PID.I am using it and is working fine for me....
10-02-2015, 07:47 PM #15
Any link to the manufacturers Web site?
