    Apr 2012
    Iraq
    36
    623
    strange defrost procedure !!
    how r u
    Samsung floor standing split ac
    classic non inverter
    R22
    29000 BTU
    220 volt
    here the temperature reached -2 C
    in heating mode
    normally unit go in defrost to melt ice on the outdoor unit
    what i know is
    when the thermistor in outdoor unit senses low temp its call for defrost
    what must happen
    just indoor fan and outdoor fan turn off and then 4 way valves revesre to cooling mode while compressor keeps work
    until ice melt then 4 way valve energized to heating while compressor keeps work
    in my case
    what happen here
    when ice severely collected on the outdoor unit
    the compressor off
    after many seconds 4 way valve reverse cycle in to cooling mode
    then compressor then run
    after ice melted compressor go off then after seconds 4 way valve revers to heating mode
    now why compressor go off for a while
    instead of continuous work as in other split ac unit
    best regards
    Power consists not in being able to strike another but in being able to control oneself when anger arises
    11,025
    Re: strange defrost procedure !!
    Some units do stop the compressor on changeover.
    Apr 2012
    Iraq
    36
    623
    why
    can u explain
    11,025
    Test reopen thread
    Apr 2012
    Iraq
    36
    623
    y
    can u explan
