    Jan 2015
    65
    2
    Indesit frost free freezer
    We have an Indesit F/F/Freezer its about 5/6 years old , could be older it's in an apt in Spain .
    everytime you switch on another appliance the unit starts to tick , the more you put on the faster the tick . But if you switch it off or pull plug out and wait 5 min and restart It's fine .
    Apart from this it works fine . What we have tried is leveling the unit / raising fridge door as it had dropped / and swipping a magnet accross the board behind the facia . Can anyone help
    Cheers Don
    May 2012
    59
    1,528
    36
    Re: Indesit frost free freezer
    You say it ticks when other appliances are started?
    This is more to do with the electrical supplies in the apartment I would think?
    When the thing is running and something else starts, for a fraction of a second
    there could be a power drop, this then causes the compressor motor to stall
    and it only recovers if left off for a few mins to equalise. The ticking could be the
    the compressor starter and, or safety device.
    If this is the case it could be an indication that the fridge, at 5 or 6 years old
    is getting tired and needs looking at or worse. Try running it on a separate plug,
    fed from as near the consumer unit, fuse board, circuit breaker board or whatever
    system the flat has for distributing the electricity.
    I would also suggest an electrician looks at the electrics in the apartment and
    checks for any problems, bad connections or low voltages.
    Rob
    Jan 2015
    65
    2
    Cheers Rob , aye the electrics in some parts need looked at , we received an electrical certficate to say it's ok , but to be honest Hind sight tells me Knowing how things work over there this could be Micky mouse .
    Don
