    Jan 2015
    singapore
    1
    Exclamation daikin error code UH
    Dear all,
    Pls give me a solution for this,
    I found UH error code on one fcu and A5 error code on another fcu. Both are connected to the same CU.(4mks80E)
    I have checked these things.
    Indoor outdoor compatiblity.
    Indoor outoor wiring and copper piping.
    Pls help me to figure out this issue.
    Is it pcb faullt fault.
    Nov 2013
    Re: daikin error code UH
    I think the A5 is a thermistor fault and uh is I wiring/ pcb with outdoor
    manchester
    5,639
    A5 Operation halt due to the freeze protection function or high pressure control
    U4 Signal transmission error (between indoor and outdoor units)
    UH Improperconnection of
    transmission
    wiring between
    outdoor and
    outdoor unit
    outside control
    adaptor
    manchester
    5,639
    lev's on outdoor are prone to sticking
    manchester
    5,639
    5,668
    From memory, Brian_UK had one of these faults a few years back - I think it's something to do with VAM'S.
    There again, I am probably wrong
    manchester
    5,639
    test cables are correct 1.2.3 corresponds with indoor 123 and check pipework isnt crossed ie unit A is piped to ports A and wired at port A terminals
    Jan 2009
    Canary Islands
    144
    If it's a system I've not seen before I will always carry out a wiring error check. Use SW3 on exterior service monitor PCB. This will confirm as Install Monkey as above.
    I've had UH a couple of times and it was a EEV coil each time. The EEV with a faulty coil does not shut and allows refrigerant to pass through an interior unit that is not in operation.
    en boca cerrada no entran moscas
Tags for this Thread
