Results 1 to 16 of 16
02-01-2015, 04:38 PM #1
Carrier Genesis R 70 trouble (video)
Best wishes for a happy New Year Brother
I have a truck Carrier Genesis R 70
The engine is running a little bit and then stops and issued a strong noise and a lot of black smoke But I note that the clutch works at the beginning ? Is not normal
There are no alarm in the Control Box !!
We have examined the battery and all Relay and fusible
I have checked the compressor and the engine manually, there is no problem everything spins running smoothly
This video
02-01-2015, 05:09 PM #2
Re: Carrier Genesis R 70 trouble (video)
Looks like belt slip to me.
02-01-2015, 05:28 PM #3
Yup Mr Brian
But in the normal state the engine is running first and then after 7 or 10 seconds and then works to clutch spins the compressor and alternator
Here are the opposite
Engine starts overload !!
Sorry about my bad English
02-01-2015, 09:23 PM #4
Fuel filter there is one in the pump near tank,one near the engine try starting it on a heat cycle adjust temperature to +20
03-01-2015, 12:22 AM #5
Hi #cadwaladr
I will try him tomorrow
Thanks brother
I will tell the results
03-01-2015, 12:31 AM #6
Ok the engine does not like too much load,but it should start unloaded take care friend
04-01-2015, 03:59 PM #7
04-01-2015, 07:58 PM #8
Try taking the belt off to compressor and see if it will run be careful only do this for a short time or engine will overheat
06-01-2015, 08:21 PM #9
06-01-2015, 09:02 PM #10
There is a bleed screw on the injection pump on the side of it think it's a 12mm spanner size,it should bleed itself thru the return line
07-01-2015, 12:19 AM #11
07-01-2015, 09:26 PM #12
Glad to help take care because I care.
15-02-2015, 12:59 AM #13
Sounds like the injector pump or injectors mate
15-02-2015, 03:08 AM #14
I think he has it sorted fixed now?
04-03-2015, 07:24 PM #15
Yeh
#Cadwalar thnx bro
Evrything work now
It's done
04-03-2015, 08:05 PM #16
Great to know,thanks for getting back to us one day I may visit your country and look you up take care.
