    Feb 2007
    newcastle but now carlisle
    195
    Need advise for stripping a ccm valve on a c02 pack
    Iv worked a lot on c02 packs and have never had to pull 1 of these valves apart before . Just after a little advise before I jump in and pull it apart
    Aug 2014
    75
    508
    Re: Need advise for stripping a ccm valve on a c02 pack
    Hi Tony
    The CCM and CCMT valves are not designed to be stripped down without special tools. Apart from the motor there are no spares available , so it is best to get a new one and replace it.
    Feb 2007
    195
    Hi Glenn
    Yip can see you need something special to pull the bipolar step motor off the valve body . Don't feel like changing the complete valve . Lol. You can get a manual adjustment to replace the step motor
    Aug 2014
    75
    508
    Hi Tony
    You can get a device to manually drive the CCM motor but there is no actual manual jacking device to manually open and close these valves. I think you may be thinking of the ICMTS valve where you can get a manual Device which is a very powerful magnet , to manually wind the valve open and closed. The CCM valves motor can driven by a handheld battery driven unit which can also be used to test the motors function . To remove the motor just de Gas the line and simply unscrew the motor from the valve body but you need a special tool as used on the production line to screw the orifice/ piston assembly down into the base of the body. If you do attempt to strip the valve have a complete spare valve on standby. Best of luck Glenn
    Jan 2015
    ca
    33
    1
    BUMP! I am bumping your post as you have some fairly urgent questions. Sorry I have to run to dentist and cannot answer myself right now. Hopefully someone else will address, if not I will try to later today.
