Results 1 to 2 of 2
Thread: Mypro-cp i
22-12-2014, 03:53 PM #1
Mypro-cp i
I keep getting an OP alarm on my MYPRO-CP I? I clear the alarm and it times out as it should but once the timer reaches 0 it will just go back into alarm. Crank case pressure at the gauge is 25 psi and the gauge is correct the set value on the panel for oil diff is low 21 psi and high 35 any suggestions?
22-12-2014, 08:00 PM #2
Re: Mypro-cp i
Is the oil pressure switch or sensor faulty?
