    May 2014
    ksa
    bitzer compressor lip
    Please I need help , my compressor Bitzer Model 4P-10.2-35 have a problem all pistons had broken and now I am making complete overhauling but the problem there's a small edge in the pistons place ( piston head ) the pistons can not go out side because of this edge what I can do ? this is the 1st time I see this ?
    what the reason of the edge ?
    3,355
    Re: bitzer compressor lip
    Quote Originally Posted by mostafaabdalla4 View Post
    Possibly excessively worn cylinders.
    Unless oversize pistons available, machine is throw a away.
    If you can instal a new piston ring in worn cylinder it may be obvious how much cylinder is worn.
    Aug 2007
    Adelaide Australia
    70
    562
    Hi Mostafa
    If you can't get the piston out of the cylinder then I would say the bores are so badly worn that the piston rings or what's left is catching.
    As Ranger has said this will be a throw away. The cost of re-sleeving the bores and replacing all the worn parts would probably be much more then the cost of a new compressor.
    I have seen this sort of wear on old recip compressors fairly often but these have been large ammonia machines and it was worthwhile repairing, but you have a small 4 cylinder compressor.
    Paul
    Born to fish, forced to work
