Results 1 to 1 of 1
    Dec 2014
    Danmark
    1
    Acson G18 remote HEAT, re-program, IR codes
    Hi.
    I bought a heat pump, or at least, i thought so. Outdoor part is a heat pump, but the indoor part is not.
    Some specs...
    Indoor unit: A5CK20C-AFAB-R
    Outdoor unit: A5LC15CR-ACPOA-R
    As you can see, my indoor unit is COOLING ONLY
    But i bought a new PCB from a A5CK20CR, but my remotes don't have heat option.
    So the big question, is it possible to "re-program" the remote, or are they hardcoded? I mean, is there a key combination to change it maybe? Alternatively, anyone got the IR code table, then i will make a IR transmitter my self
    Greetings from Denmark
    Thanks.
