Results 1 to 10 of 10
    Apr 2012
    Iraq
    36
    623
    fridge and freezer door not seal properly
    my experience in refrigeration is near to zero
    i get call for fridge and freezer doors
    which are not seal properly
    so what are the cause and the fixes
    how to check if the cause was the plastic sealing or the hinge
    how to check and fix
    Power consists not in being able to strike another but in being able to control oneself when anger arises
    11,025
    Re: fridge and freezer door not seal properly
    Hi Keith, keeping safe I hope.
    Door seals are simple plastic with magnet strips built in.
    It is often found that the flexible part between the door part and the seal part have splits which allow air in.
    If small you might be able to add some flexible sealer to cover the split but it is best to replace the seal.
    Apr 2012
    Iraq
    36
    623
    ok
    what about hinges
    11,025
    Hinges can go out of adjustment due to bad usage.
    Normally a couple of screws to tighten up, maybe a worn pin.
    Auckland
    74
    3,357
    37
    Hi kefah.
    good to here from you.
    As per Brian UK, it is always hinges that wear and need adjustment.
    Apr 2012
    Iraq
    36
    623
    ok
    but tyhe freezer i checked the door is stands when opening
    which mean hinges not bad
    is that correct
    3,856
    If the floor is not level it can make the fridge or freezer twist then the door does not fit well, sometimes they have adjustable feet to level them when the floor is bad.
    Dec 2008
    South Wales
    61
    I concur with Mr Spanners. Always check that the appliance is level left to right, and front to back. Before adjusting the hinges.
    Nov 2014
    Pakistan
    check for alignment of the doors at first. if alignment is ok and doors seem to be properly aligned with the body but still there are spaces left between the body and gaskit(rubber part where magnet goes) try to use warm water or a mild heater-heater. this will resolve i hope
    Apr 2012
    Iraq
    36
    623
    ok
    how to make alignment
