    13
    toshiba 3 pipe problem
    Hi got problem with recentley installed tosh 3 pipe system.when the units turned off on controller gas is passing through the indoor coil and freezing up.when it was installed the engineer forced the valves on bs boxes open.do they need setting back? What could the problem be tosh tech been unhelpful.
    13
    Re: toshiba 3 pipe problem
    Its been running 3 weeks fine until now
    Feb 2007
    2,473
    45
    Crossed wires / pipes between BS box and indoor units?
    Oct 2012
    Russia
    42
    392
    Dyna Doctor help you.
