Thread: Daewoo u20dcb problems
25-11-2014, 12:03 AM #1
recently our Daewoo u20dcb side by side started have problem icing up on back panel of freezer
and not freezing correctly in freezer some soft items near top so read a service manual defrosted
it with a little help from steamer also read if back panel has any gaps may cause problems so
applied some foam tape reassembled seamed fine for a couple of weeks checking for errors every
day have now discovered a couple of things last week sure I had error D1 51 but more
concerning today is error C1 in service manual says C1 Cycle : abnormal or defective
although freezer seems fine a few degrees out same for fridge too
advise please chaps, on one occasion sure d sensor item 2 on service was showing something like d298 and d3 00
and any one local to Sunderland, uk willing to help
attached a few pictures taken of what it was like during process
25-11-2014, 03:30 AM #2
Re: Daewoo u20dcb problems
not fully understanding some of the technical reporting like "sure d sensor item 2 on service was showing something like d298 and d3 00" can you explain what your referring to there is that a result of a diagnostic test in service mode or a error code?
if you have refrigeration experiance does your sealed system seem okay? from your frost pattern it strikes me as a defrost issue possibly a failed defrost thermistor other things that come to mind evap fan intermittant opperaton, stuck compressor relay, failed bimetal (if equiped), failed heater, etc.. though i think less likely. I work on appliances for a living I'm having difficulty recognizing that model it does look familar to some bosch units i've worked on though are you able to upload or link to your service manual so i can follow allong? first thing is first though i always start by eleminating the sealed system as a possibility.
25-11-2014, 07:10 PM #3
the one I went from tried to upload but to big there's one similar here
http://www.fridge-manual.com/manuals...oo_FRS-U20.pdf
page 23 takes you through the steps I mentioned as follows this mornings results
1. 00 27
2. -f1 15
3. d2 39
4. r0 92
5. t2 54
6.p1 00
7.f1 lt
er c1
tonight's results
1. 04 18
2. f0 48
3. d2 40
4. r1 40
5. t2 77
6. p1 00
7.f1 lt
er c1
if I power off the error clears for a short while
26-11-2014, 08:18 AM #4
had a similar problem with my daewoo , turned out to be the fan motor starting to fail , fan was working most of the time but wasn't spinning as fast at it should but worked most of the time , it eventually failed completely , got a new motor from ebay for about £30 and problem sorted
(this was the fan that sits inside the freezer at the top for clarity) apparently daewoos are quite reliable but the fan motor is a common failure on them
29-11-2014, 01:34 AM #5
any one know what Pull Down mode is and does.
fridge temp around 16 .c
