    Apr 2006
    Libya
    Help with York air conditioner.
    I have a problem with a 47000 BTU/hr York split type air conditioner R407 C ,which has a damaged orifice type of metering device but I cant find it in my country ,so I decided to replace it with TEV but I just foud TEV for R22 of the same capacity ,will it work properly with R407 C if I replace it?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Help with York air conditioner.
    It can work, but consider that the sensitive liquid in the bulb has a different expansion coefficient for R22 and for R407c. I think you will be able to let it work nonetheless.
    olaitan's Avatar
    olaitan Guest
    hi mohammed qasim wish to know u am from nigeria the last time i did a work on r407 was to change the compresor replacing with r22 if u need to know
    Jul 2009
    U.S.A.
    7
    can you give me help about the calculation on york aircondition in window type package, window package and duct type plzz..
    Mar 2005
    u.a.e
    68
    169
    It will work but observe it and adjust super heat acordingly.
    Jul 2009
    U.S.A.
    7
    how to compute the btu per room.. because our professor given us a project about installation of york aircon..
    Mar 2005
    u.a.e
    68
    169
    Try to visit heatcraft refrigeration site
    you will find heat calculation sample sheets, get familar and put your required data to calculate total btu heat for a room, in fact this is for low temp but you can get an idea that how to calculate it.
    malik55
  1. York Chiller
    By HVACGod in forum Commercial
    Last Post: 11-09-2010, 06:05 AM
  2. YORK ducted split
    By ALONEI in forum Trouble Shooting
    Last Post: 10-07-2010, 02:18 AM
  3. York Wiring Diagrams
    By iceman007 in forum Trouble Shooting
    Last Post: 10-04-2010, 06:48 PM
  4. York Screw Oil Problem
    By tomt in forum Technical Discussions
    Last Post: 02-12-2009, 02:48 PM
  5. York process chiller repairs
    By Matt in forum Commercial
    Last Post: 23-03-2004, 11:07 PM
