    Nov 2014
    Singapore
    4
    How to reset/clear on error code on PAR-21MAA Remote Control after replace drain pump
    Hi there can anyone here help in advising on how to clear the error code on the wired controller
    Nov 2014
    Singapore
    4
    Re: How to reset/clear on error code on PAR-21MAA Remote Control after replace drain
    This is for the Mitsubishi VRF air-con
    Nov 2014
    Singapore
    4
    The Fan coil is PLFY50
    11,025
    Has the fault been repaired ?
    Reset is via the self check history display.
    www.mitsubishielectric.com.au/assets/leg/par-21maa.pdf
    Nov 2014
    Singapore
    4
    Hi Mr Brian, in the shortest and most straight-forward approach method. Is it by depressing the "On/Off" button twice and press start button. From there it should clear up on the last error code on the display. This was taught by one of my co-worker.
    Kind Regards,
    Tim
    Oct 2007
    manchester
    5,639
    45
    press check button twice to display the fault code, press clock on/off button twice quickly to clear after when the fault has been rectified
    Last edited by install monkey; 05-01-2015 at 09:51 PM. Reason: ps theres no start button on a par 21
