Results 1 to 21 of 21
    Dec 2004
    Weihai,China
    800
    typical refrigeration cycle
    Hi sirs
    is there a kind of software which can simulate a typical cycle of refrigeration system? while you change any parameter ,system can reach a new balance point like a real machine operating.
    Any clues,thanks
    regards
    LC
    Jun 2005
    California
    394
    Re: typical refrigeration cycle
    Lc Shi This may be what your looking for
    http://energy.sdsu.edu/testcenter/index.html Roger
    Dec 2004
    Weihai,China
    800
    It's really a good web.
    I'd like to learn it.
    How about you experience on it?
    thanks
    LC
    Aug 2005
    5,302
    HI LC,
    MY experiences with system modeling is that you will have to write specific "modules" for each system component.
    As an example for a compressor: This module would have to include capacity and power input calculations for changes in rotational speed, suction superheat, re-balancing of the suction and discharge pressures, refrigerant used, etc. I have done this for a computer program once before for a screw compressor and it was a LOT of work.
    Similar modules would also have to be created for evaporators, condensers, and the refrigerant metering device.
    Quite a project to begin.
    There are some programs used in the chemical engineering field for system modeling bu they are very expensive. These are intended for refineries and other processes. They have modules you can add to a diagram. When the individual modules are linked together you can "run" the system and change operating parameters.
    Jun 2005
    California
    394
    Quote Originally Posted by Lc_shi
    thanks
    LC
    I joined as an academic instructor which is free but is limited unless i agree to pay some money but it's not expensive. I am still learning how to use it properly but the tutorals are good , they olny take time however. I believe once you know how to use it you can simulate any thermodinamic process and find a solution.
    Jun 2005
    California
    394
    Quote Originally Posted by US Iceman
    HI LC,
    Iceman you need to look at the web site
    Oct 2003
    5,630
    34
    Wambat,
    I downloaded also the academic version and I don't think you can't simulate the behavior in a real cool process.
    I think what Lc_shi wants is that he can see what happens with the equilibrium point when for example subcooling increases.
    This is something difficult to calculate.
    You need the curves for each specific item you used in the system and some curves can't be made nor found.
    Aug 2005
    5,302
    Hi guys,
    Here is a link Josip posted some time ago.
    http://www.frigosoft.no/frigosim/
    It is also expensive but it does look like it was built for refrigeration systems.
    Dec 2004
    Weihai,China
    800
    Yeah,I download it but not received demo llicense.
    Feb 2006
    11
    I use Engineering Equation Solver (EES), also known as Ease for modelling refrigeration cycles. It is great at solving simultaneous equations and has the thermophysical property data for lots of fluids.
    Oct 2003
    5,630
    34
    CAn you provide a link please?
    Aug 2005
    5,302
    Peter,
    Here is the link for the EES program. I have this program also and find it very useful. You have to create your own modeling equations for the refrigeration system.
    You can curve fit any data such as compressor ratings or others and use it within the program. EES already has a large group of refrigerant and other fluid properties that you can use.
    There is a learning curve to this program, but after you become familar with it I think you will like it.
    http://www.fchart.com/ees/ees.shtml
    Tor Henriksen's Avatar
    Tor Henriksen Guest
    Sirs
    I think the program you are looking for is this one. Its very easy to use and you have every thing you needs to simulate what ever you want.
    Down load it from www.et.du.dk/CoolPack
    Jan 2006
    Croatia
    68
    2,261
    31
    Hello,
    Tor Henriksen
    Sirs
    I think this is right becuse:
    The programs in CoolPack covers the following simulation purposes:
    • Calculation of refrigerant properties (property plots, thermodynamic & thermophysical
    data, refrigerant comparisons)
    • Cycle analysis – e.g. comparison of one- and two-stage cycles
    • System dimensioning – calculation of component sizes from general dimensioning
    criteria
    • System simulation – calculation of operating conditions in a system with known
    components
    • Evaluation of operation – evaluation of system efficiency and suggestions for reducing
    the energy consumption
    • Component calculations – calculation of component efficiencies
    • Transient simulation of cooling of an object – e.g. for evaluation of cooling down
    periods
    To make it easier to get an overview of the programs in CoolPack we have chosen to divide the
    programs into three main groups (Refrigeration Utilities, EESCoolTools and Dynamic).
    Here you can download Tutorial or CoolPack program, as you like:
    http://www.et.web.mek.dtu.dk/Coolpack/UK/download.html
    Best regards,
    Josip
    Feb 2001
    Tampa Florida
    1,076
    Hi, LC. I am just curious what particular instances you experience where you see this to be a valuable tool.
    For example, are you wanting to design equipment? That's the first thing that comes into my mind. And if so, what particuar problems are you trying to overcome? For example, are you concerned about the dimensions of heat exchangers and compressors because of physical limitations?
    Or are you looking at such a tool in order to suggest replacement equipment to a customer?
    I am just curious.
    Dec 2004
    Weihai,China
    800
    Hi Dan
    Yes, my work is equipment design. At concept stage I need to evaluate the design feasibility. Usually we can only calculate the parememters at 1 or 2 states.It's hard to predict the dynamical performance. Of course,the final design should be by prototype test. However,a good and practical simulation tool is of great help
    rgds
    LC
    Aug 2005
    5,302
    Quote Originally Posted by LC
    This is why I liked to do simulations on equipment performance, especially before the product or system is designed.
    This allows you see the interaction of the various parameters in the dynamic situations. Then you can change one aspect of the component or system to achieve higher performance values.
    I was involved in one project where we did this for a screw compressor. By changing the geometry of certain features we could see the result before designing castings. Sort of like CFD.
    Oct 2003
    5,630
    34
    The EES program Mxstart mentioned - I thought I had seen the logo of F-Chart and the box with the 3 E's somewhere - is already included in Coolpack.
    LC-Shi!!!
  19. #19
    Jan 2006
    Croatia
    68
    2,261
    31
    Hello Peter_1
    Here we use some pills, don't know what could be the name in english (what is not so important) but they act as "antiforgetting" pills.
    NHF, please
    Dear LC-Shi...
    FrigoSim demo licence works only (as I remember) with salt water and R22 what is not too much useful and full version is quite expensive. It is better to stay in touch with CoolPack and some other free programs. See my post under "Free sofware, hm but not all" maybe you can find something there
    But if you need to do the serious job/project I think company should find the budget to buy the tools ,
    what you mean?
    Best regards,
    Josip
  20. #20
    Aug 2005
    5,302
    Hi Peter,
    You are correct. Coolpack is based on the EES program.
    I wish the EES program could draw the same nice looking log-PH diagrams you can generate with the refrigeration utilities program in Coolpack.
  21. #21
    Apr 2006
    Iceland
    61
    8
    I use a great program from Solkane. You can access it at: http://www.solvay-fluor.com/library/...000040,00.html
  1. advanced refrigeration technology
    Last Post: 16-02-2011, 05:22 PM
  2. closed cycle air refrigeration
    By shogun7 in forum Refrigerants
    Last Post: 03-03-2004, 08:17 PM
