Results 1 to 2 of 2
Thread: Samsung AVQ19 heater problem
09-11-2014, 07:32 PM #1
Hi all
I have a Samsung AVQ19 air conditioner. It has been working well since last two years (both its cooling and heating sections). Recently, I wanted to start its heater but it did not work.
When I pressed the ON button and changed its mode to HEAT, two of its three LEDs were permanently on. But its fan did not work and no air is produced. However, after some minutes, it generated beeps and two of its front LEDs started blinking. They only stopped blinking when I pressed ON/OFF button again.
The cooling unit is working well.
After I have searched in the web but I could not find any solution.
I uploaded some pictures to mention the problem.
Does anybody can help me to solve this issue?
Thank you in advance.
13-11-2014, 02:30 PM #2
Re: Samsung AVQ19 heater problem
hi amir
and welcome to our forums
your air conditioner is split ac unit ?
also after turning on the unit from remote control
check if the outdoor unit works or notPower consists not in being able to strike another but in being able to control oneself when anger arises
