    Jun 2008
    gloucester
    44
    72
    scotsman ice machine fault
    Hi guys have an mv306 on arrival to site bin is empty and led 3 (bin full) is flashing. Any help much appreciated
    Oct 2007
    manchester
    5,639
    45
    Re: scotsman ice machine fault
    turn it off and on again- magnetic switch sticking on bin full ?
    http://saranarefrigeratama.co.id/dow...s%20manual.pdf
    Jun 2008
    gloucester
    44
    72
    Hi when I turn it on off it starts up then bin full led flashes is not steady like maybe in wash mode think I'm going to get new pcb and front display Tried linking out switch did the same thing. Cheers
    Oct 2007
    manchester
    5,639
    45
    did you click on the link for the service manual on my previous reply
    Jun 2008
    gloucester
    44
    72
    Yes thanks a lot for that doesn't really tell me about the problem I've got
    Nov 2014
    London
    41
    13
    Check the sensor on the bin that indicates the bin is full or not, if its not lined up. It will think its full and it will not make any ice
