Results 1 to 9 of 9
    Oct 2014
    Pakistan
    7
    How to calculate refrigerating capacity at given temperature ?
    i have been given a problem ..
    An ammonia ice plant operates b/w condenser temperature of 35c and an evaporator temperature of -15c.it produces 10tons of ice per day from water at 30c to ice at -5c .assume simple saturation cycle
    calculate Cpacity of refrigeration plant ??
    how to find this ? plz help me..
    Auckland
    74
    3,357
    37
    Re: How to calcualte refrigerating capacity at given temperature ?
    54.52 Kws evaporator duty.
    Q= ( C1 x TD ) + Latent + ( C2 x TD ) = 470kj/kg
    10,000 kg /24 hours = 0.116 Kg/ second.
    Evap duty = 470kj/kg x 0.116 Kgs/ sec = 54.52 Kws
    Oct 2014
    Pakistan
    7
    thank you brother....but can u explain it...what is D1,TD C2 ??
    Split Croatia
    57
    6,151
    36
    Where do you see D1?
    C is specific heat of matter
    TD is temperature diference
    C1 is specific heat of water
    C2 is specific heat of ice
    You have temperature difference of water from 30° to 0°C = 30K x Specific heat of water x mass of water, which is total sensible heat of water
    You have temperature difference of ice from 0°C to -5°C = 5K x Specific heat of ice x mass of ice, which is total sensible heat of ice
    And you have specific latent heat of changing water of 0°C to ice of 0°C x mass of water/ice which is total latent heat of frezzing of water to ice
    Adding that together you get your heat needed to remove in order to cool water from 30°C to 0°C, freeze it and cool ice further to -5°C.
    Oct 2014
    Pakistan
    7
    sorry about the D1 ( its miss typing) ,
    thank you so much brother, for the explanation.it helped me alot
    Auckland
    74
    3,357
    37
    Hi ijazali
    what type of ice machine are you working with, tube ice, sheet ice, block ice, etc..
    Jul 2014
    egypt
    can u explain this in more details with numbers ??
    Q= ( C1 x TD ) + Latent + ( C2 x TD ) = 470kj/kg ????????/
    thank you very much
    fathy
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, semoo112
    Quote Originally Posted by semoo112 View Post
    thank you very much
    fathy
    my advice .... you need to read the thread from beginning to follow calculation procedure ... within nike123 post you have definitions ... what is what ...
    and then you will catch the numbers .... numbers are irrelevant ...
    and then you can change them as you like or as you need ... quite simple ...
    another way is to search RE forums for cooling capacity calculation ...
    something you can find on the WEB ....
    something about Ice in fisheries ... good to read ...
    http://www.fao.org/docrep/t0713e/T0713E00.htm#Contents
    some calculation
    http://www.fao.org/docrep/t0713e/T07...f ice required
    about water and ice ...
    http://www.fao.org/docrep/t0713e/T07... water and ice
    Hope this will be of some help to you ...
    Best regards, Josip
    Oct 2014
    Pakistan
    7
    Hi ijazali
    its actually a problem in my book, iam still studying ..
