    Oct 2007
    jersey channel islands
    186
    Mushroomed suction nut on service port.
    Just wondered if anyone had come accross .
    mushroomed suction service port nuts , the ones that cover the open and shut allen key access.
    i used to tjink they had been over tightened.
    but now i am not so sure.
    my idea is that as the suction freezes ( comms room unit).
    moisture tracks past the threads into the void of the valve and inside of the nut.
    and over a period of time ,gets to the point where. The flat face of the nut fractures.
    or am i barking up the tree.
    Its rzq dakin unit.
    Oct 2001
    Nottingham UK
    5,668
    Re: Mushroomed suction nut on service port.
    I'd go with the over tightened theory...it would take hell of an ice ball to crack it..never come across a cracked one myself - flare nuts, yes, but service valve covers...no
    3,357
    Quote Originally Posted by still learning View Post
    Its rzq dakin unit.
    Got a picture,
    Formation of Ice is very powerful, would have to be around - 15 deg C to expand though.
    If you filled with grease or similar would keep water out, messy though!
