Results 1 to 12 of 12
    mrmtata's Avatar
    mrmtata Guest
    intermittent starting fridge/freezer
    Hi guys,
    i have a problem with a domestic fridge freezer, namely when the unit is switched on it will click quietly into life, run the compressor for around 5 seconds and then with a loud click will switch off.
    With the unit on there is power all the time at the control panel but the compressor only switches on about once every 5-10 mins, like i say for about 5 seconds at a time.
    This unit is only 2 years old but is out of warranty, any advice before i purchase a new one would be much appreciated.
    cheers
    mrmtata
    Oct 2004
    Scotland
    1,454
    21
    Re: intermittent starting fridge/freezer
    Hi mate,
    Sounds like the comp is goosed.
    You could try and buy a new starter for it (relay) but it's probebly not worth it.
    Try switching it off for 24hours and then test it again.
    Make sure there is plenty air flow for the hot bit at the back (condensor).
    Chillin
    and go get a cuppa
    Apr 2006
    US
    10
    I would try a 3-in-one start kit before you trash it. Kit cost about twenty dollars or so.
    Oct 2001
    Nottingham UK
    5,668
    This sounds like the classic case of the R134a blocked capillary
    Stat calls, compressor kicks in, runs into a vacuum, no compressor cooling, klixon operates. Compressor then cycles on klixon
    mrmtata's Avatar
    mrmtata Guest
    Thanks for your ideas, i left the unit off for 12 hrs last night, flicked it on this morning and got the same result. I will try leaving it off for 24 and see what happens.
    Frank, re the blocked capillary it this a terminal problem or can it be repaired?
    I will look into the 3 in 1 kit.
    cheers guys.
    mrmtata
    Apr 2001
    2,099
    27
    Your compressor is faulty Im afraid
    mrmtata's Avatar
    mrmtata Guest
    Thanks for the advice guys, much appreciated.
    cheers.
    Oct 2001
    Nottingham UK
    5,668
    I believe there are small hydraulic hand pumps for clearing capillaries although I have never used one. If the gas in your fridge is R134a and the capillary is embedded in the insulation panel then it will end up cheaper to buy a new fridge.
    R134a tends to wax the oil and block capillaries.
    If you have access to a line tap valve and a manifold set then you can easily check to see if the compressor is pulling a vacuum.
    Feb 2006
    derbyshire
    610
    let try another way,when it runs does it get the condenser coils hot if so the system sounds o/k and i would go for the relay,or it could be the run winding ,if it runs for a while and the condenser stays cold or cool,bin it,system fault,just as a after thought, if the compressor gets its supply from a PCB board and not a normal t/stat,check it has 240v, sometimes you get low voltage and poor conections that throw you.
    Oct 2001
    Nottingham UK
    5,668
    lets try another way,when it runs does it get the condenser coils hot
    I think this would be difficult to do with a run time of 5 seconds
    Feb 2006
    derbyshire
    610
    ooooooooer, i read that wrong,though it was longer, naf pot then.
    Sep 2005
    spain
    54
    comp nackerd scrap it i had same prob and changed relay worked for 1 week then no go.
  1. starting of defrost time
    By pirestani in forum New Technologies
    Last Post: 28-06-2006, 04:11 PM
  2. freezer section of fridge/freezer has stopped
    By roobydoo in forum Domestic
    Last Post: 30-05-2005, 08:35 PM
  3. RFI Interference from Fridge/Freezer
    By pathfinder in forum Trouble Shooting
    Last Post: 19-03-2005, 11:50 AM
  4. Starting a compressor, and receiver questions.
    Last Post: 24-08-2002, 12:37 PM
  5. Intermittent Compressor Rotor Stall (LRA) Symptoms
    By JONAH in forum Trouble Shooting
    Last Post: 26-03-2002, 10:43 PM
