Thread: Trane
    May 2010
    ireland
    Trane
    Hi, I have a trane air conditioning unit gas burner. Unit runs, valve is letting gas in but not igniting?Red LED on board is a constant flash, no sequence
    May 2010
    ireland
    Re: Trane
    It is a 75KW unit
    Dec 2008
    563
    Re: Trane
    Possibly the igniter has failed.
    If you are not a Gas Safe registered engineer, it would be best if you called in your local qualified gas heating engineer.
