    Oct 2014
    Germany
    1
    Liebherr ICBS 3156 : fan freezes
    I have a Liebherr ICBS 3156 fridge.
    For a few months now we have a problem with it:
    Ice builds up around the fan, and this obviously creates problems.
    A few weeks ago we turned off the fridge for a while and detached the inner panel at the back of the fridge to check if the fan was still operational despite being frozen for so long.
    We discovered that behind this panel everything was frozen. It took a while in fact to detach it because of this. When everything was unfrozen I checked the fan and it actually appears to work: I made it spin by connecting it to a 9V battery.
    We cleaned everything and put everything back in place.
    Unfortunately a few days after that the freeze was back.
    It looks like the fan never spin and this lets the freeze builds up.
    Do you know what I should do ?
    Thanks a lot.
    Split Croatia
    57
    6,151
    36
    Re: Liebherr ICBS 3156 : fan freezes
    It looks like you need service engineer to check electrical and automation part of fridge for correct functioning. It could be many causes.
    fan not spinning
    door switch faulty
    defrost heater faulty
    automation of defrost proces faulty
    air flow obtruction
    low refrigerant charge
    etc...
    Jul 2006
    norfolk
    737
    change the evaporator sensor
    check out my website www.airkooldomestics.co.uk
