Results 1 to 15 of 15
Thread: c room ices up
    Mar 2011
    34
    101
    14
    c room ices up
    Hi guys got a coldroom r404a the unit ices up every 2 weeks its elec df all gas prssures are ok but i checked all perameters
    Df stop temp 20
    Fans active no
    Def duration 20
    Def cycles every 4 hours
    Fan start temp 0
    Its a single heater evap which works well have i missed anything when checking it over also the drain is clear any help is appreciated
    Apr 2008
    Southampton, England
    49
    1,023
    36
    Re: c room ices up
    Hi Matt,
    Does the defrost probe read correct?
    Defrost heater getting hot?
    Yeah, the obvious bits I guess you've checked but this caught me out once:
    Defrost heater come unclipped on the bottom of the coil (Rivacold blower). Coil heated up a bit, enough to get probe hot but back of coil not clearing, just melting a bit so a week later iced back up.
    Cheers,
    Andy.
    Jan 2012
    West midlands
    44
    33
    Re: c room ices up
    Sounds like the is door being left open. Is their a door switch or curtain?
    If not that I would second the defrost probe faulty or located to close to the heater bar.
    After that is the controller relay stopping at temp or solenoid passing.
    Somerset
    69
    4,698
    Re: c room ices up
    Hi Matt.
    Has the products that are being stored recently changed?
    Only some seasonal products have High moisture contents.
    Has the frequency of the through-put changed.
    Even more basic Has the drain line vapour seal or the door threshold seals been damaged
    Someone may have to pay for you to spend some time with this one. The answer will be their somewhere?
    Have you got lazy staff that leave the door ajar whilst they load to and from the store.
    Stupid it may be but the above can happen.
    Sorry coolhand I have just read your post.
    Great minds eh!
    Oct 2007
    manchester
    5,639
    45
    Re: c room ices up
    if its a walk in freezer- increase the defrost duration - to say 30 mins, just in case its not clearing all the ice, as others say check the door closes properly and the seal is compressed, also any air balance vent not closing?
    had issues with a searle freezer a few mth ago- like an icy wonderland in there- blocked drain , replaced it all in 32mm plastic , no issues since ( watch me get a call out to it now!)
    Mar 2011
    34
    101
    14
    Re: c room ices up
    Well i read all your posts and i know the seal is good the door os alsp self closing the drain is clear the only thing i am assuming at the minute is the chefs put cardboard boxes directly under the fans restricting the air flow
    Aug 2013
    horsham
    37
    28
    Re: c room ices up
    Increase the duration to 45mins. I have had similar probs with a zanotti, end temp set to +5. Make sure the probe reads good and is at the top of the coil as far from the heater on the inside of the blower if possible.
    What type of blower is it?
    R ALLATT's Avatar
    R ALLATT Guest
    Re: c room ices up
    What make and type of evaporator do you have
    Mar 2011
    34
    101
    14
    Re: c room ices up
    I think its a luve evap
    Oct 2009
    77
    243
    Re: c room ices up
    Is it snow or ice on the evap.
    Is there a drain down parameter if so set to 5mins.
    Put through a defrost and check if there is any ice still on the evap. if there is move termination sensor to this position.
    R ALLATT's Avatar
    R ALLATT Guest
    Re: c room ices up
    I would check you have the right speed evap fan motors fitted.
    Fully defrost the coil put on defrost and if the controller lets you, watch what temperature the defrost probe terminates the defrost.
    Sep 2013
    uk
    Re: c room ices up
    hi, could possibly be the liquid line solenoid valve passing .
    also if an electronic controller is being used check the compressor relay isnt sticking ,seen this many times
    Sep 2009
    Iran
    66
    672
    1
    Re: c room ices up
    where is the position of Evap. in room . it is important .
    Jan 2006
    Adelaide , Australia
    192
    Re: c room ices up
    1 fan freezer iced up.jpg like this
    or fluffy ice on back face
    60% of the time it works everytime.
    Jan 2006
    192
    Re: c room ices up
    Quote Originally Posted by mattym View Post
    Df stop temp 20
    Fans active no
    Def duration 20
    Fan start temp 0
    Some answers above are for freezer system ice ups.
    But you say its a coolroom ? Sounds like a freezer setup , heaters and fans active =no
    The back pressure ( LP ) must be low for it to ice up if a coolroom ?
    If its not LOW then make controller work on time only not temp termination.
