    Mar 2008
    37
    12
    Mitsi Electric Air Con/Heating Interface
    Hi All,
    Wondering if anyone has come across the same situation and has a solution?
    A customer wants his air con to be cut-off when his existing heating system is on by means of a pipe thermistor on the radiator in the room.
    Is there an adaptor or accessory that mitsubishi make that could provide this?
    Or will I have to come up with something using a MAC-397IF coupled with a thermistor and thermostat?
    Any help would be greatly appreciated as i have not done something like this before.
    Thanks,
    John
    Dec 2008
    564
    Re: Mitsi Electric Air Con/Heating Interface
    John,
    Dependant on the Mitsubishi model that you have, you could use the simple and cost effective PAC-SA89TA interface and connect this to a strap on pipe thermostat.
    This could be set to turn the A/C unit off or on depending on the set point of the thermostat.
    No external power source or relays needed.
    Bedford. Now retired and trying to relax.
    Mar 2008
    37
    12
    Thanks hyperion!
