30-09-2014, 11:34 AM #1
Heat Pump problem. How can I solve this? What are the steps ?
I was trying to solve this as part of my preparation. But don't have a clue as to how to solve it. What are the steps ?
30-09-2014, 09:06 PM #2
Re: Heat Pump problem. How can I solve this? What are the steps ?
You have to work out the temperature of the brine leaving the bore hole collector.
01-10-2014, 02:38 PM #3
01-10-2014, 06:05 PM #4
your ice acts an insulator,
01-10-2014, 08:41 PM #5
Thank you for your reply. So do I have to assume the temperature difference in the borehole ? and would 5 deg c be reasonable?
How do I get the ground temperature which is needed to find out the evaporator temp. ? I'm very confused..!!!
Can you please provide me with a step by step solution. That will be a great help...Please..!!
