    Sep 2014
    Sweden
    3
    Post Heat Pump problem. How can I solve this? What are the steps ?
    I was trying to solve this as part of my preparation. But don't have a clue as to how to solve it. What are the steps ?
    Aug 2009
    New Zealand
    54
    2,556
    Re: Heat Pump problem. How can I solve this? What are the steps ?
    You have to work out the temperature of the brine leaving the bore hole collector.
    Sep 2014
    Sweden
    3
    But, What is the use of of ice thickness on the bore hole collector pipe ?
    Aug 2009
    New Zealand
    54
    2,556
    your ice acts an insulator,
    Sep 2014
    Sweden
    3
    Thank you for your reply. So do I have to assume the temperature difference in the borehole ? and would 5 deg c be reasonable?
    How do I get the ground temperature which is needed to find out the evaporator temp. ? I'm very confused..!!!
    Can you please provide me with a step by step solution. That will be a great help...Please..!!
Tags for this Thread
