Thread: F-Gas question
28-09-2014, 08:46 PM #1
F-Gas question
I have read on a leaflet from a supplier that from 1st January 2015
"there must be no maintenance or servicing undertaken on R22 equipment that involves breaking into the refrigeration circuits"
I am reading this as you can no longer fit gauges to R22 systems unless you are decommissioning the system , is this correct ?
28-09-2014, 09:06 PM #2
Re: F-Gas question
Yes that is correct.
If you put gauges on then all you can do is remove the gas for disposal.Brian - Newton Abbot, Devon, UK
28-09-2014, 09:56 PM #3
Re: F-Gas question
An Interesting question gsracer. With the correct answer given by Brian!
Many still have yet to comprehend the full significance of Jan 1 2015.
Despite the minimum training of 2079. There are huge numbers of R22 systems around and little being done about it.
2015 will be an interesting year no doubt.
28-09-2014, 11:11 PM #4
Re: F-Gas question
Yes Grizzly, I think that a few people will come unstuck when we are unable to "perform" our magic on some of these older systems.
