Results 1 to 12 of 12
Thread: Heat Pumps
12-04-2006, 10:22 PM #1
Heat Pumps
Some discussion has been occurring on the use of heat pumps and renewable technologies for industrial applications. During some surfing several links were found that may prove interesting to some of you.
Maybe we can generate some good discussions on the use of heat pumps and the various refrigerants that can be used.
One more way a refrigeration system can be used...
http://ehpn.fiz-karlsruhe.de/en/
http://sherhpa.fiz-karlsruhe.de/en/
http://www.heatpumpcentre.org/Public...se_Studies.asp
13-04-2006, 01:56 AM #2
Re: Heat Pumps
Oil shortage surely need more high effeicient ways of energy use. Heat pump is the very choice. I pay special attention at ground source heat pump. May be the best way is to combine it with building.
I think most application of heat pump should be in the AC field but the excavation cost limit its use in small system . In building dense country like China,how to use GHPs is a challenging job
I hope this threas can get together a team to lead this topic to the depth.
best regards
13-04-2006, 11:52 AM #3
Re: Heat Pumps
Originally Posted by Lc_shiIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
13-04-2006, 02:24 PM #4
Re: Heat Pumps
Hi Milo,
This is a very good link you have posted. I think this shows there are good alternatives , and many sources where heat pumps can be used.
I was a little surprised they decided to use the raw sewage, however, the article does not really provide too many technical details.
Somewhere in the past I seem to remember the sewage systems use a rotating screen/filter in the primary flow to separate the large particles (rats was the term used in the article).
One project I was involved in was similar to this except we were using the clarified water (what they call brown water I believe) as the source for the heat. This was essentially clean water, but not potable.
The system consisted of several large chillers with water cooled condensers. Heat was pulled from the clarified water and transferred to large manufacturing buildings across the road.
This is exactly the the type of technology transfer we need to see occur to assist in the reduction of our dependency on primary fuel sources.
While some members may say this is a waste of money, I completely disagree. This is most definitely a case of a wise investment into a proactive solution.
I believe we will begin to see more of this as energy continues to become more and more expensive. Some may stick their heads in the sand and say this will never happen, some are more energetic to understand and attempt.
Thank you for sharing this with us.Last edited by US Iceman; 13-04-2006 at 02:26 PM. Reason: spelling
13-04-2006, 03:16 PM #5
Re: Heat Pumps
Here are some other interesting examples of heat recovery, one is using a heat pump in a ventilation system.
And another reclaiming heat from a compressed air system.
http://www.energy.ca.gov/reports/200...03-096-A13.PDF
http://www.gfxtechnology.com/GFX-STAR.html
http://www.heatpumpcentre.org/About_...P_industry.asp
http://www.compressedairchallenge.or...s/factsh10.pdf
http://europa.eu.int/comm/energy_tra...hptortech.html
13-04-2006, 07:23 AM #6
Re: Heat Pumps
Interesting links.
On HPs, much has been said. Convenience is contradictory, especially in northern europe, canada and north USA. In general terms, in continental countries over 55° latitude HPs are not a high efficient way of using energy.
GHPs are much better in terms of performance, and we are pushing a lot on this.
13-04-2006, 08:43 AM #7
Re: Heat Pumps
I found this story
http://news.yahoo.com/s/nm/20060407/...ment_sewers_dc
Cant say I'm looking forward to the hands on work
13-04-2006, 09:54 AM #8
Re: Heat Pumps
Originally Posted by milo
Even companies like coka-cola and putting funds into CO2 technology. I Think the reality is that these technologies, including solar refrigeration are going to become very common place in the industry. And sooner than anyone had antisipated.
14-04-2006, 07:29 PM #9
Re: Heat Pumps
All food factories have effulent plants, with the waste at between 20 and 30 deg c. Also laundry plant wastes heat at these temperatures and higher
Way to go I think.
Kind Regards. Andy
13-04-2006, 11:10 AM #10
Re: Heat Pumps
Amazing. HFS, Heat from ****.
Now, it sounds anachronistic to know some countries are still using R12 and R22, and farwesterners own cars with a fuel consumption of 10 miles a gallon, while in Europe we do all efforts to hurt our economy by spending money on such HFS projects.
13-04-2006, 10:40 PM #11
Re: Heat Pumps
One thing in their favour with the Swedish system is that the country has been using district heating systems for years and can take advantage of that.
Here in the UK, for example, there are few of these schemes. The problem with all of these ideas, I believe, is getting the accountants to see the bigger picture.Brian - Newton Abbot, Devon, UK
14-04-2006, 02:31 AM #12
Re: Heat Pumps
Originally Posted by Brian_UK
This does provide a lot more flexibility in what can be provided as the infrastructure is already there. Developing this concept from scratch would require some enormous capital investment.
Which can be one of the obstacles to overcome for these systems to be economically feasible.
High Temp Heat Pumps
By US Iceman in forum Heat PumpsReplies: 68Last Post: 29-05-2011, 05:19 PM -
frostles heat pump
Heat pumps a bonus for House buyers?
By mick2me in forum Heat PumpsReplies: 21Last Post: 14-11-2006, 01:27 PM -
New Subject - Swimming Pool Heat Pumps
By LanzaCarlos in forum Trouble ShootingReplies: 8Last Post: 09-02-2006, 01:58 PM -
Heat Pumps as main heating...?
By daddymac in forum DomesticReplies: 21Last Post: 07-12-2005, 09:59 PM
