Thread: BRC1D52 Daiken
    Aug 2014
    Erbil
    5
    BRC1D52 Daiken
    Hello , it is possible to get a KWH from this remote controller through a BMS system , if not any solution ? Thanks
    5,668
    Re: BRC1D52 Daiken
    It's not a function of the BRC1D controller.
    Assuming that it is a simple split type of system you are talking about, for kWh monitoring you need to insert a kWh meter onto your power supply to the outdoor unit.
    http://www.crompton-instruments.com/...rs_06_2009.pdf
    Aug 2014
    Erbil
    5
    Re: BRC1D52 Daiken
    Thanks for your reply , no it is VRV system , any advice for this VRV System with multi Flats about one hundered each have this remote ?
    5,668
    Re: BRC1D52 Daiken
    You will need the Intelligent Manager accessory for this ...not a cheap option though
    http://www.daikinac.com/content/asse...0low%20res.pdf
Tags for this Thread
