    Oct 2010
    taiwna
    5
    Pls provide Stal S83 & S26 swept volume
    Hi brothers,
    Would you kindly provide Stal S83 & S26 swept volume .
    Both motor's spec are 3 phase 380V 60HZ, compressors max speed are 4000 rpm .
    Thanks a lot!
    Best regards
    Croatia
    68
    2,261
    Re: Pls provide Stal S83 & S26 swept volume
    Hi, Jeter Lin
    Quote Originally Posted by Jeter Lin View Post
    Hi brothers,
    Thanks a lot!
    Best regards
    STAL-MIMI MkII - S26
    at 50 Hz 700 m3/h max shaft input power 250 kW
    at 60 Hz 840 m3/h max shaft input power 300 kW
    Hope this will be of some help to you.
    I believe if you search RE forums you can find some capacity data regarding STAL S-83
    Best regards, Josip
    Oct 2010
    taiwna
    5
    Hi, Jeter Lin
    Best regards, Josip
    Dear Josip
    I'm so deeply apprciated your kindness.
    Thanks your help again.
    Best regards
    Jeter
