Results 1 to 11 of 11
    Sep 2014
    philippines
    Condenser approach temp
    The trane RTWD condenser was cleaned. The approach temp. before was 25°F and now it's 14°F still high. I am suspecting about the volume of water entering the condenser. Is there any instruments to measure the amount of water entering?. I saw that the scales in the tubes were removed. Pls...help
    Thank you...
    Split Croatia
    57
    6,151
    36
    Re: Condenser approach temp
    You need ultrasonic flow meter for that purpose.
    moideen's Avatar
    moideen is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2008
    u.a.e
    49
    412
    23
    overcharged system may indicate higher condenser approach.
    3,357
    Quote Originally Posted by roelescence View Post
    Thank you...
    Did you look down or blow through each tube to make sure they are not blocked.
    Chemical clean not always perfect if blocked in middle of tubes.
    Have you checked water strainers, sump water level & pump operation.
    Are there any valves, etc in water lines that could restrict flow.
    Also water sprays in cooling tower.
    Aug 2014
    75
    508
    Is the water flow in the condenser the correct way around ?
    Mar 2012
    italy
    67
    78
    13
    Use a differential pressure gauge to measure the pressure loss.
    check the correct pressure drop from the manufacturer's manual.
    Sep 2014
    philippines
    There are gate valves and check valves in the water line. Gate valves are old but we've just replaced the check valves
    Sep 2014
    philippines
    There are check valves in the water line, and flow cannot be reversed
    moideen's Avatar
    Apr 2008
    u.a.e
    49
    412
    23
    what is the inlet and outlet temp of condenser?
    Sep 2014
    philippines
    Condenser inlet is 84.2°F and out is 92.1°F.
    By the way pls analize this reading for the compressors:
    L1 92.5%
    L2 93.5%
    L3 100.3% of its rated current. Isnt it imballanced?
    moideen's Avatar
    Apr 2008
    u.a.e
    49
    412
    23
    As per your condenser delta T (8F) the chilled water flow is ok. But your inlet water temperature is high considering local ambient wet bulb temperature. I think your wet bulb is 70F (google).then condenser inlet should be 75F.arount 9f is high. Check your cooling tower whether it is performs. When inlet temperature is high, approach also will be high.
