Thread: help with brema ice maker
11-09-2014, 09:42 PM #1
hi, i have a brema ice maker cb 30 model, r404a, water cooled condensor,
tripping out on head pressure @30bar. removed gas and weighed back in factory charge,thing is works ok while im there and an hour later trips out,at start of cycle head pressure goes as far as 26 bar and drops as the cycle goes on,water regulator valve is fully open and water supply seems ok,any ideas appreciated,thanks.
13-09-2014, 06:22 PM #2
Re: help with brema ice maker
Whats the water quality like? Scale likes to build up on the hot spots of heat exchangers, how smoothly is the water valve moving. Once you know the hx and valve are opperating correctly then we can look into the rest of the system, sticky lls weak hp switch so on.
Now in Redvers Sask.
13-09-2014, 06:47 PM #3
any strainers on the water circuit?
13-09-2014, 09:38 PM #4
Is this a new system ?
What type of condenser is it ie Shell & Tube,Plate ?
Which way does the water flow through the condenser, in the bottom out the top , in the top out the bottom ?
14-09-2014, 08:51 AM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Faulty water regulator valve, maybe. Or water supply intermittent cut offs.
Are you sure in your correct model name?
14-09-2014, 11:27 AM #6
Exchanger with low heat transfer due to dirt.
low flow of cooling water.
