Results 1 to 2 of 2
    Sep 2014
    United Kingdom
    1
    John Lewis (Electrolux) Mdl. No. JLBIUCL01 Prod. 923734715 is running too cold
    This fridge is actually freezing but before i go and change the thermostat, it is also making a low frequency hunting noise. Is this sign of something more serious or is it just because it is having to work extra hard because of a failed thermostat
    Aug 2014
    75
    508
    Re: John Lewis (Electrolux) Mdl. No. JLBIUCL01 Prod. 923734715 is running too cold
    sounds like the compressor is running into a vacuum due to the low temperature it is running at. Suggest you fit a new stat asap before the compressor cooks itself to death br Glenn
