    Jun 2012
    Pakistan
    44
    Water Chiller Technical Specification and Cable/Breaker Sizing
    Dear fellow ,I am confused by technical specs of chiller and installed cable and breaker rating.
    Following technical specs are written in chiller docs.
    Absorbed Power = 86 KW
    Nominal operating current = 145 A
    Max operating current = 244 A
    Now which of above parameter should be used for cable and breaker sizing? .
    It is worthy to mention that chiller is water cooled twin screw compression chiller.
    I have found that contractor has used 70 mm2 cable and 400 A rating breaker.
    Please share your expert views as I suspect that above sizing is not compatible with chiller rating.
    manchester
    5,639
    Re: Water Chiller Technical Specification and Cable/Breaker Sizing
    look at lra - locked rotor ampage, your lenght of cable run, type of cable used, whether its in free air, will determine your cable size, the fuses are designed to protect the cable from melting
    see the link
    http://www.openelectrical.org/wiki/i...ng_Calculation
    Jun 2012
    Pakistan
    44
    see the link
    Can I take maximum operating current as LRA?
    The only information I have in this case is mentioned above .
    plz help in this case .
    manchester
    5,639
    whats the make/model number of the chiller?, theres no harm in oversizing the cable -apart from the additional cost
    Jun 2012
    Pakistan
    44
    Chiller model : Interklima (Greece) WWC-105
    manchester
    5,639
    ive checked the sales info and doesnt state any compressor reference to check lra
    best to contact the sales office as if your going to be buying 1 then they should provide you with an installation manual prior to ordering
    Contact
    70o klm Athens - LamiaHalkidaPO 191 73 34 100 Greece
    +30 2262085600
    +30 2262085728
    http://www.interklima.gr
    Jun 2012
    Pakistan
    44
    Let I put in simple what I intended to ask. (For the time
    being put all other things aside, plz )Theoretically which of following parameter is considered for breaker/cable sizing?
    manchester
    5,639
    max operating current
    Quote Originally Posted by pakblogger2012 View Post
    Oct 2008
    newbury
    1,444
    Voltage: 400V
    Load: 221.7kW / 400A
    Length: 20m
    Method of Installation: Clipped direct
    Cable Size: 150mm˛
    Jun 2012
    Pakistan
    44
    Split Croatia
    6,151
    Cable is sized according to start method of compressors, allowable voltage drop, cable length, placement, ambient conditions and many more factors influencing proper function of Chiller.
    Therefore, it is job for electrical engineer to make calculation and other details for correct cable size choice and installation.
    Breaker is sized according to chosen cable and type is chosen according to maximum starting current and duration of start condition.
