    Aug 2014
    Australia
    43
    2
    Mitsubishi City Multi ambiant temperature sensor control question
    Just wondering if anyone could tell me if the ambient temperature sensor has a influence on any operation of the system, reason being a site I have been working on the ambient temperature sensor on oc has been running 10deg+ lower than os I think it maybe getting influence off the other units coil as they have been installed quit close together , I havnt had a chance to investigate further as of yet but wondering if it influences the control logic in anyway ,
    Any info appreciated thanks
    Oct 2001
    Nottingham UK
    5,668
    Re: Mitsubishi City Multi ambiant temperature sensor control question
    It will be there for a purpose and the data it provides to the main processor will be an important part of the overall control system.
    On a Daikin VRV, the ambient sensor inhibits heating mode when the temp is in excess of 23C.
    I would imagine that the Mitsi logic has some similar control as well as additional functions, which the alogarithms need to compute compressor speed, valve openings etc
    Aug 2014
    Australia
    43
    2
    Thanks for the reply frank I would have thought the same but I can not see any literature on it anywhere, I will move the sensor but wondering how many others out there are the same and what problems it may or may not cause to help diagnose what may be a simple fix ,
    I would imagine that the Mitsi logic has some similar control as well as additional functions, which the logarithms need to compute compressor speed, valve openings etc
