    Jul 2011
    usa
    29
    oil manifold o-rings
    Hi.
    I just changed out the o-rings and end washer on my piston valve cps blackmax manifold set. The instructions said to oil the o-rings after installation, but had no suggestion as to what oil to use. I mostly do r134a, so my first though is to throw some POE on there, but, that's just going to get contaminated with moisture, then migrate...
    Anyone have a suggestion for an oil that is resistant to migration?
    BTW, I know people like to bag on CPS, but it's been a good set to me, and the repair kit was under 10$ shipped. Can't beat that!
    Thanks!
    May 2012
    59
    1,528
    Re: oil manifold o-rings
    The amount of oil will be negligible in the big scheme of things.
    Your only going to put a small drop on your finger tip and then move
    the o ring between them.
    I would not worry about the type of oil used because it will be such
    a small amount, that it won't mater.
    I've just repaired about 4 of our gauge manifold sets and I used a smear
    of vac pump oil oil that I had in the store cupboard.
    I also use the CPS sets (among others) and I like them also, they do what
    they are supposed to do and are reasonably priced.
    Rob
    Jul 2011
    usa
    29
    Thanks! I always have plenty of pump oil handy.
    3,853
    I think yellow jacket makes some grease just for doing the o rings, but like Grizzly said, i'd probably use what was to hand.
    4,712
    ERM!
    I said what?
    Grizzly.
    3,853
    ERM!
    I said what?
    Grizzly.
    haha, um..... what Rob said!
