17-08-2014, 08:28 PM #1
York millenium recip chiller fault
Hi guys! pls help me with this fault from York millenium recip chiller, YAEP model. The unit doesn't start. it shows "REPROGRAM TYPE OF REFRIGERANT TO RUN". it needs access code to change the type of refrigerant..
18-08-2014, 07:33 PM #2
Re: York millenium recip chiller fault
er662,
tell me has the chiller been commissioned ?= sedgy
18-08-2014, 08:44 PM #3
How old is chiller?
19-08-2014, 07:47 PM #4
it's a six-yr old chiller
19-08-2014, 10:39 PM #5
It may be that the battery on the micro board has failed, normally this message only appears when chiller is first switched on, you may need to change other settings if the memory has failed, each time power is lost then this will reoccur, would you not be happier to contact local York office to check it for you?
