Thread: Carrier 30HZ 065 pro-dialog
09-04-2006, 11:00 PM #1
Hello All,
Can anyone tell me how to change circuit A & B lead lag operation. I have the manual and have tried everything. Can anyone let me know if I am dumb as a bag of hammers or have I a problem.
10-04-2006, 07:54 PM #2
Re: Carrier 30HZ 065 pro-dialog
Hi CuGe
sorry little experience with this plant, but you need the controller manual and the sytem pass word to change the lead lag.
Try putting the first circuits compressors off on service, the second set will take the load and then put the first set back on line after this.
Still think U need the manual
Kind Regards. Andy
10-04-2006, 11:04 PM #3
CuGe
Try this link -
http://www.carrier.com.lb/products/C...prodiagxhx.htm
and click on the Technical Information link at the bottom right of the screen; this will give you access to the Pro-Logic manual as a pdf download (4.32mb).
I think it is around page 24 that it gives the configuration instructions to change the lead/lag of the machine.
Hope this helps.Brian - Newton Abbot, Devon, UK
11-04-2006, 12:50 PM #4
if it is a pd4 (white) -> user1 menu -> item 1 ->
0 means - automatic
1 means - lead A
2 means - lead B
if earlier (black) -> configuration menu -> intem 2
0 means - automatic
1 means - lead A
2 means - lead B
(same as above)Last edited by hiitsme; 11-04-2006 at 12:54 PM.
11-04-2006, 01:11 PM #5
you can reach these menus only if the unit is LOFF mode.
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
Carrier Water Chillers
By Latte in forum Air ConditioningReplies: 10Last Post: 11-10-2008, 08:43 PM -
Carrier chiller oil migration
By lowtech in forum IndustrialReplies: 5Last Post: 30-04-2006, 04:11 PM -
carrier remote
By superswill in forum Trouble ShootingReplies: 2Last Post: 26-04-2006, 09:17 PM -
Carrier spares
By daddymac in forum Air ConditioningReplies: 6Last Post: 21-03-2006, 08:54 AM
