Results 1 to 2 of 2
    Aug 2014
    Latvia
    38
    1
    Beko thermostat problem
    Hello!
    I have a Beko CSA29010 fridge. We have transported it to a new home. It was cleaned so it looks as good as new and turned it on.
    After a night of working, we noticed that the freezer is a little cold (but not enough) and the fridge it self is room temperature.
    I tried adjusting the thermostat but it doesn't seem to be doing anything. When you turn it on, it makes the usual running water sounds and engine noise.
    Can somebody advice me on what can I do without throwing the fridge out? Any advice will be welcome.
    Oct 2007
    Republic of south africa
    48
    184
    Re: Beko thermostat problem
    I think you should call a professional to check it out to zero in on the actual problem. There are a few things which can produce such symptoms.
