    Split Croatia
    6,151
    Saladette foamed evaporator TD
    I recently worked on this equipement:
    http://ipelican.com/en/55712
    What makes me wander is, what is correct evaporator TD for such type of equipment?
    Evaporator is embed in foam on 3 side of compartment and in midlle of doors is small forced air portion of evaporator.
    I measured, in perfectly working unit, evaporator TD of 20K. It looks to me little excessive since I expected number of close to 15K.
    Any taught on this?
    Also, compressor used is for LBP. Is this common practice for "professional" equipment (it is made in China)?
    ireland
    1,450
    Re: Saladette foamed evaporator TD
    These things are churned out in the thousands, warranty lasts as long as the wholesaler as one in stock. I've never paid attention to the td i must admit, if it cooled i was happy. I've seen LBP compressors used on bottle coolers from china, bit of a learning curve going on there i think
