    Apr 2012
    Iraq
    35
    623
    compressor burned 4 capacitors
    i get a call from my friend
    he said that his 24000 btu split ac unit had bad capacitor
    so he replaced it with same size and specification
    he said the unit worked perfectly for 30 min then stopeed working
    so he replaced the capacitor again and the unit worked for 30 minutes then stopped working
    then replaced for third time then forth time with same result
    the compressor is rotary type
    made by LG
    Feb 2007
    2,473
    45
    Re: compressor burned 4 capacitors
    And the measured running current of the compressor is?
    Oct 2001
    Nottingham UK
    5,668
    Did he test the capacitors or just guess that they were at fault?
    Dec 2010
    Toronto, Canada
    1,454
    One definition of insanity is performing the same task over and over and expecting a different result, haha. I can maybe see changing it once without checking the current draw, but 3 times?
    Apr 2012
    Iraq
    35
    623
    i will ask him then reply u
    Oct 2007
    Republic of south africa
    49
    184
    Most likely caused by compressor drawing excessively high current.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    With the situation Iraq is in at this time, i'm thinking a stable power grid might be a problem. Low or fluctuation voltage.
