Results 1 to 16 of 16
Thread: Samsung code
    Aug 2014
    Martinique
    54
    11
    Samsung code
    Hi everyone,
    I need the samsung option code for AQV09UGEN (for the remote controler).
    Thanks very much.
    Feb 2007
    2,473
    Re: Samsung code
    OK,
    Let's make sure I get you the right code,
    Are you after the option code to enable a wired or upper level controller to be used?
    OR
    Have you changed the unit's circuit board and need the unit's product option code to be programmed via the remote controller and, if so, what type of controller do you have?
    Aug 2014
    Martinique
    54
    11
    Re: Samsung code
    I changed batteries' remote control unit.
    After that, I taped a code for a similar model AQV09UGAN.
    But it was not good
    Aug 2014
    Martinique
    54
    11
    Re: Samsung code
    But it was not good
    My model is AQV09UGEN
    Feb 2007
    2,473
    Re: Samsung code
    OK,
    But if you just changed the batteries of the infra red remote controller then there isn't any need to enter a code...
    Does anything happen if you press the ON/OFF button on the remote?
    If not, look at the IR transmitter at the front of the remote via a digital camera, like the ones found on a modern mobile phone, does the IR transmitter blink when you push the buttons?
    Aug 2014
    Martinique
    54
    11
    Re: Samsung code
    Yes but I entered the code 044777 - 17d20d, the remote controller unit didn't function.
    And lamps on indoor unit are continuously flickering
    Aug 2014
    Martinique
    54
    11
    Re: Samsung code
    And anything happen if you press the ON/OFF button on the remote
    Feb 2007
    2,473
    Re: Samsung code
    Quote Originally Posted by REINE View Post
    OK,
    So exactly what happens when you press the ON/OFF button?
    Aug 2014
    Martinique
    54
    11
    Re: Samsung code
    When I press the ON/OFF button, I can read
    SET and fan icon
    But the air conditionner don't work
    Aug 2014
    Martinique
    54
    11
    Re: Samsung code
    SET and I see a fan icon
    But the air conditionner don't work, air flow blades are closed
    Feb 2007
    2,473
    Re: Samsung code
    OK,
    So the screen on the remote changes but does anything actually happen on the AC unit itself?
    If not, see post #5 above about using a digital camera to check the IR transmission and let us know the result.
    Aug 2014
    Martinique
    54
    11
    Re: Samsung code
    yES, the screen on the remote changes but nothing actually happen on the AC unit itself
    And the IR transmitter is blink when you push the buttons
    Aug 2014
    Martinique
    54
    11
    Re: Samsung code
    And the IR transmitter is blink when I push the buttons
    Feb 2007
    2,473
    Re: Samsung code
    OK,
    Have you tried the ON/OFF button on the indoor unit itself?
    If that didn't do anything, try pressing the K3 button inside the outdoor unit.
    Aug 2014
    Martinique
    54
    11
    Re: Samsung code
    I tried the ON/OFF button on the indoor unit itself and that didn't do anything
    But where is the K3 button inside the outdoor unit ?
    Aug 2014
    Martinique
    54
    11
    Re: Samsung code
    It's raining and it isn't possible to reach the outdoor unit now.
    I will try when it is possible and I will recontact you.
    Thanks very much
