    May 2014
    thermostat wire probe , long deli fridge
    Can someone give me a hint ? I have found that the 2 wires from a thermostat probe have come off and were free in junction wire box under fridge and that will be why compressor and the fridge (long deli type ) was running eratically , were do i connect them there is no diagram no makers name except its italian any help at all however obvious the method as i am a novice thanks
    3,856
    Re: thermostat wire probe , long deli fridge
    Are they mains power wires or temperature probe wires?
    Might have to just start again and re wire it if you can't figure it out but it is worth drawing out a diagram of what you know first as often it is then clearer where thing need to go for it to work.
    Republic of south africa
    49
    184
    How many terminals are on the thermostat. Take a picture of the thermostat and post it so that the gurus on the forum can help you.
Tags for this Thread
