Results 1 to 9 of 9
    Aug 2014
    usa
    43
    1
    Unhappy old r12 walk in freezer won't drop below 3*.
    Sight glass is clear. Superheat at compressor is 20*. Both coils clean. It's an old semi hermetic, I thought the valve plate was bad. Changed out the valve plate expecting a super efficient compressor, but got no improvement. Not familiar with r12, I think the suction was at like 12 psi, witha bout 10* box temp. The damn thing runs and runs.
    Apr 2006
    41
    1,620
    23
    Re: old r12 walk in freezer won't drop below 3*.
    What state is the condensor at?, what is the ^t on the filter dryer?
    TXV or Cap. so much info missing here
    Now in Redvers Sask.
    Split Croatia
    57
    6,151
    36
    Superheat at evaporator? Frost pattern at evaporator?
    11,025
    Why are you working with/on R12 ????
    3,856
    Door seals? cold room panels ok?
    Mar 2010
    56
    5
    Quote Originally Posted by jasonrd View Post
    What head pressure do you have?
    Oct 2007
    manchester
    5,639
    45
    you sure its a freezer, not a fridge
    Dec 2008
    564
    How long has the box been offline? What is the insulation like? If it has completely thawed and then the insulation has got wet, it will take a long time to re-freeze the insulation. As it was designed for R12 and is therefore probably quite old, you would be lucky to get down to 3degF or are you meaning 3degC? What are the suction and head pressures, is it fully or over charged. Have you got any restrictions at the drier?
    Bedford. Now retired and trying to relax.
    Apr 2006
    41
    1,620
    23
    One hit wonder, think it safe to say no need for futur rplies here till they can be bothered to post above stated data.
