    Jan 2014
    Uk
    40
    91
    12
    Mini clamp meter
    image.jpgimage.jpgAlrite lads,
    I'm after a mini / slim jaw clamp meter mainly for splits, the 1 I've got is too big to get run amps off fans and comps without snipping the outer sheath off the cables.
    I've seen this martindale mini clamp that seems ok and a kewtech or the other name it has with really thin jaws.
    Any1 use similar?
    Cheers andy
    Oct 2007
    manchester
    5,639
    45
    Re: Mini clamp meter
    dont buy the isotech 1 rs do with the detatchable head- peice of ****e!- got a milwaukee off ebay for a ton which does ac dc current,capacitor tester and hertz, jaws are ok, except for panasonic urbans with the terminals on the rh side
    Feb 2007
    2,473
    45
    Just read the spec and make sure it works on square waves and varied frequencies as generated by inverters.
    Most small, cheap, clamp meters only give accurate readings at 50Hz sine wave.
    Oct 2007
    Republic of south africa
    49
    184
    Apr 2012
    Iraq
    36
    623
    here in Iraq
    the Kyoritsu is very good but Fluke is better
