01-08-2014, 02:55 AM #1
Help w/ starting issue on Carrier XTC Reefer
Hi. I have a 2006 Carrier XTC reefer that I am having a starting issue with.
When the reefer sits off for a day, and I go to start it, it will not start, and I get a code A35 for "Check Starter Circuit". If, I clear the alarm, and try again after a little bit, the unit will start.
Once it starts, and I set it on cycle mode, it will run fine, between cycles.
I have replaced the starter, and starter relay. Battery is new, and alternator is charging properly.
Any ideas on what the problem could be, or what I should check? Thanks.
01-08-2014, 03:51 AM #2
Re: Help w/ starting issue on Carrier XTC Reefer
Check your oil pressure switch. With Micro revision 5.07 if the op switch is stuck closed (any continuity at all across the switch) it will trip a code a35 (check starter circuit) before it even tries to crank.
04-08-2014, 05:55 PM #3
Update the software to U05.09.00.
