    Jul 2014
    43
    8
    Daikin Skyair indoor on VRV III S
    Does anybody have succesfull installed the sky air units on the vrv III outdoor unit?
    I have a RXYSQ-P7Y1B VRV-III-S Outdoor unit.
    Now i installed 3 new indoor units:
    FTXG 35 Emura
    FTXG 25 Emura
    FBQC 50 DUCT unit
    Branchprovider unit 3 rooms.
    Now i get fault UA
    Wrong indoor units ?
    When i orderd the units i asked daikin if it is ok they said no problem you can connect them to the vrv III as long as you only combine the sky air indoor unit.
    Maybe somebody know how to install it
    Do i need to change some thing on the pcb board?
    Hope somebody knows this because i want to get them running.
    Already sent a mail to Daikin but they are very slow with responding
    Stef
    Oct 2012
    Russia
    42
    392
    Re: Daikin Skyair indoor on VRV III S
    Did you made 51 mode on?
    Jul 2014
    43
    8
    Yes but it looks like it forget the 51 mode.
    The units is a RXYSQ6 P7Y1B
    I am thinking that the software on the board does not support 51 mode
    Can anyone confim this?
    If so i order the pcb from the P8Y1B unit i thinks this is exact same print only software newer
    Oct 2012
    Russia
    42
    392
    1. After setting 51 mode turn off outdoor unit for 5 min.
    2. Disconnect Checker if you have it
    Oct 2001
    Nottingham UK
    5,668
    Do the Skyair indoor units have their own outdoor units and you are connecting them to the VRVIII-S with the adaptor pcb's or are you trying to pipe the Skyair indoor fan coils onto the VRVIII-S fridge pipework?
    Oct 2012
    Russia
    42
    392
    Sky + BP unit + VRV3S. I`ll start up that config.
    p.s. do you have wired controller for duct unit?
