Thread: carrier 950 twin compartment
30-07-2014, 10:14 PM #1
unit runs well on stby but on engine faults up check and shuts down so check idle\ high speed \oil and water ? or what else will fault it many thanks
31-07-2014, 05:56 PM #2
Re: carrier 950 twin compartment
Check gas,if the suction transducer detects less than point seven bar it shuts down and says system check on the display
31-07-2014, 10:00 PM #3
many thanks
01-08-2014, 03:54 AM #4
also check your fans, could be icing up and tripping the system check alarm. Fans run off the standby motor so it could be working on standby but not on diesel.
02-08-2014, 05:01 AM #5
02-08-2014, 06:19 AM #6
01-08-2014, 02:39 PM #7
Good point forgot about that one,and it seems the most likely.
24-08-2014, 11:32 PM #8
what fault code is displayed on cab command?
